Which way is it going?
Discussion in 'Project Cars' started by Rewedmiata, Feb 24, 2011.
  1. Rewedmiata
    m12 x 1.5 an-6 banjo fitting and 15 or so feet of an-6 fuel line. So ya little things.
  2. Straitup D
    ill have about 20 or sao feet of steel braded line left over, IIRC its -6an too! i can have it ready next week!
  3. Rewedmiata
  4. Straitup D
    Delivered!
  5. Straitup D
    sooooooooo it runs?
  6. Rewedmiata
    Line didn't fit, ordered new line should be here today.
  7. Rewedmiata
    [video=youtube;iDXhwpE6KIg]http://www.youtube.com/watch?v=iDXhwpE6KIg[/video]
    [video=youtube;eLzvuWbF53c]http://www.youtube.com/watch?v=eLzvuWbF53c[/video]
  8. Rewedmiata
    Fuel system
  9. And then?!?!?! When should I come over again?
  10. Rewedmiata
    any time man
  11. Rewedmiata
    Spring update, got new emulsion tubes swapped in. Got new brakes all around (11 inch wilwood kit bp10 pads and 1.8 hps rear) and a proportioning valve.Got all my gauges to work, just need to figure out a bulb/led solution to the vdo gauges in the the cluster since the lights that came with them stick out to far for the gauges to fit in the housing. finally rewired the fuel pump, no longer requiring me to jumper the diag ports to keep it running. Rewired most of the stuff I did last minute last year thus fixing the random short i had. Stuffed in the new seat (pita). Now photos!
    Now issues, the wilwood kit is to big for my rpf1s. One of the 1/8 npt to M10x1.0 fitting stripped since the rear brake hard line i had to replace had a non oe fitting on it that striped it. So waiting on 15x8 +35 PF01 and 225/45r15 Toyo R1Rs and a replacement fitting for the valve to show up. Other than that its clean up time. Reloom my new/modified wiring, start finding all my lost tools that are scattered in/around the car. Probably find a better radiator shroud and fans.
  12. Rewedmiata
    Looking a bit more complete, brake line fitting also showed up. Swapped the front studs out for ARP extended units. Also started getting the interior back to one piece, worked on getting the other seat in. Got the a/c delete tube back in place after getting the grommets in to protect the wires going thru the holes.
    Now working on redesigning the throttle bracket to keep it from flexing, and more wire clean up/mounting the brake lines since the OE holders have succumbed to age. Slowly coming along, still need a alignment and to swap in the ARP studs in the rear. Now its just a bunch of little things.
  13. Derrian
    Love!
  14. cmspaz
    Awesome that it's this close! Are you planning on just track time at PG or are you going to run TTS?
  15. Rewedmiata
    The plan is to just get it on the road. I've changed so much of the car I'm more into finding out what I have to adjust/change to get it to drive the way I like/hope.
  16. Rewedmiata
    [video=youtube;V5nZ5QBbI2E]http://www.youtube.com/watch?v=V5nZ5QBbI2E[/video]
  17. Rewedmiata
    Highway driving[video]https://www.youtube.com/watch?v=z8ORe0bkSTw[/video]
    [video]https://www.youtube.com/watch?v=9RzE0gicmy8#t=239[/video]
