Rod Millen joining Rhys for his own run up Pikes Peak
Discussion in 'Car News' started by garagegeeks, May 28, 2011.
    Filed under: Motorsports, Hyundai
    RMR Hyundai Pikes Peak 2011 Test Session - Click above for high-res image gallery
    Chances are you've heard of Rhys Millen. The man pushes cars over dirt, into extreme sideways angles, through the air and up challenging mountain roads. If you're a bit younger, however, you may not have heard of his father, Mr. Rod Millen... and that's a problem, because you should know that name.
    Rod Millen, born in New Zealand and possessor of the best driveway on the planet, is a racing legend. Typically known for his off-road records, the elder Millen has been hustling rally cars and trucks across tough terrain since the 1970s. The company he founded, MillenWorks, is responsible for the development of technical innovations used in racing, and by the military. Enjoying that cushy suspension setup in your Chevrolet Corvette or Audi R8? You can think MillenWorks for that.
    Like Rhys, Rod also has a passion for competing. Before Nobuhiro Tajima came along, Rod Millen was the Pike's Peak record holder. Driving a Toyota Celica All Trac in 1994, Millen smashed the previous record by 40 seconds. He broke his own record four more times, until the Monster took him down, and Rod hasn't been back since 2001.
    Father's day is around the corner, and the Millen boys are ready to spend some time together. They're going to do so in Colorado, because Rod is coming back to the mountain, and Rhys is planning to destroy it.Continue reading Rod Millen joining Rhys for his own run up Pikes Peak
    Rod Millen joining Rhys for his own run up Pikes Peak originally appeared on Autoblog on Fri, 27 May 2011 19:25:00 EST. Please see our terms for use of feeds.
