Random Finds
Discussion in 'Lounge' started by Rewedmiata, Oct 6, 2011.
  1. Rewedmiata
  2. Rewedmiata
    Oh an Forza 4 is up at the WSP Wallmart, go get it!!!!
  3. DoughtCom
    DoughtCom New Member
    That red Legacy is beautiful, makes me want to build one!
    I hate cars.
  4. Grappler
    Legacy = win!
  5. Derrian
    James! Buy that Legacy MEOW!
  6. 1Kris06
    Erik, your car(s) need MOAR backfire.
    [video=youtube;O3zQTEEkm3k]http://www.youtube.com/watch?v=O3zQTEEkm3k&feature=player_embedded[/video]
  7. 1Kris06
    More random,
    Want to buy the Lotus with the K24 swap you saw at C&C
    Only 49.9k
    1999 Lotus Elise (Series 1 – 111S) - Limited Edition Sport 190
    Extremely FAST Track-Day Car with Collector Value
    Lightweight – 1742 lbs (Corner Balanced April-2011)
    Performance-Built Honda/Acura TSX K24 2.4L K-Series – 300bhp (Dyno@265whp)
    Honda/Acura RSX Type S Six-Speed Transmission
    A little history on the Sport 190…
    Developed for the dedicated track fan and for fully-fledged motorsport applications, the Elise Sport 190 is pure racer. Released in very limited quantities (>60 units), only 26 of these were shipped to the U.S. with a custom left hand drive configuration.
    Originally equipped with a highly modified Rover VHPD 1.8L DOHC K-Series 4-Cylinder with a modified head and VVT technology, it produced 190bhp (142 kW; 193 PS) vs. the 118bhp delivered in the base Elise. It was also equipped with a competition-standard suspension, closer-ratio gearbox, headlamp covers, rear-spoiler, cross-drilled brake discs, alloy window winders and 6-spoke road wheel design with competition Yokohama ADVAN A048 Tires.
    Standard equipment on the Sport 190 is a RAC-approved competition roll-bar, lightweight plexiglass windows (glass windscreen), FIA-approved competition seat, mounting and six-point safety harness, battery master switch assembly, small competition battery, competition towing eye & oil cooler.
    This particular model also came equipped with a passenger seat, four-point safety harness, plumbed-in fire extinguisher, metallic paint, driving lamps and an extensive list of Lotus Sport original performance products.
    Removable Momo Steering Wheel
    Fire Bottle Extinguishing System (with Plumbing) / Fender & Dash Pull Activation
    Corbeau Driver’s Racing Seat / Less Aggressive Matched Passenger Seat
    6-point Safety Harness (Driver) / 4-point Passenger Safety Harness
    RAC Approved / Cross-Braced Roll Bar w/Petty Bar (petty bar currently removed)
    Front & Rear Tow Eyes
    Strengthened Suspension Components
    Battery Kill Switch in Cockpit / Fender Pull
    Adjustable Front Anti-Roll Bar
    Suspension Upgrades
    Cross-Drilled Aluminum Belled Performance Brake Rotors
    Pagid RS-14 Brake Pads
    Stainless Brake Lines
    New Wheel Bearings (Sealed)
    Nitron Dampers/Eibach Springs/Helper Springs (Custom developed by Chris Randall – UK Race Legend)
    Extra Set: Lightweight Technomagnesio 5 Spoke Wheels (Black)
    Hankook Ventus Z214 DOT Slicks
    Cost: $5K
    Aero Upgrades
    Adjustable Rear Wing – Painted to Match
    Adjustable Front Splitter – Painted to Match
    6-Fin Extended Rear Diffuser
    (Entire bottom of car flat sheet metal panels)
    Cost: $3K
    Cockpit Upgrades
    Nylatron Shifter Bushings
    Plexiglass Door Windows/Rear Window
    Momo Race Wheel / Momo Shift Knob
    Chatterbox Intercom System with Passenger
    Traqmate Shift-I Progressive Shift Light
    Large Bullet Lights / (1) MIL Light (Malfunction Indicator) / (1) Over-Rev Indicator
    Traqmate HD GPS Data Logger System w/ Camera Control (See Video! Very Cool!!)
    Cost: $2.5K
    Engine/Drivetrain Upgrades
    2011 Engine/Transmission Conversion - Removed and Crated original Rover VHPD 1.8L DOHC/5-Spd Transmission. – Goes with car in the event the car is ever restored to original collector condition.
    Replaced with:
    2004 Acura TSX K24 2.4L (Honda) – Performance-built to 300bhp (265whp)
    Assistance with ENDYN Racing / Ft. Worth, TX
    Z3 Racing Head – CNC Ported & Polished – Enlarged Valves – Racing Valve Train
    ENDYN Cams – 12.5:1 Forged/Coated Pistons – Crower Racing Rods (to 9500rpm)
    Balanced Crank – Fluidampr Harmonic Balancer
    Honda K20 Oil Pump / CNC Port by ENDYN
    Honda K20 Aluminum Oil Pan with Clockwise Motion Oil Sump Baffle
    Remote Canton Oil Filter (w/changeable cartridge)
    MOCAL Laminova Water-Cooled Oil Cooler System
    All New Engine Components (Bearings, Chains, Tensioners, Water Pump, etc)
    Cost: $10K
    Intake System
    Skunk2 Pro K-Series Intake Manifold
    Skunk2 70mm Throttle Body
    Skunk2 Racing Composite Fuel Rail
    Custom Fabricated Cold Air Intake with K&N Filter
    Cost: $2K
    Fuel Management
    Bosch Injector Dynamics ID725cc Injectors
    Upgraded Performance ‘In-Tank’ Fuel Pump (K24 requires higher pressure)
    K-Tune Fuel Pump Regulator – Black Anodized
    Stainless Steel Braid Oil/Fuel Lines w/Black Anodized Fittings
    Cost: $1K
    Exhaust/Header System
    Header System / Custom Fabrication – Full Blown Motorsports
    MagnaFlo Racing Muffler
    Powder Coated - Black
    Bosche O2 Sensor
    Cost: $2K
    Engine Computer
    Honda PRB ECU with Hondata KPRO Programmable ECU Upgrade/w Software
    Cost: $1K
    Transmission/Drivetrain
    2002 Acura RSX Type S 6-Speed Transmission
    Exceedy Lightened Flywheel – 8.5lb
    Exceedy Racing Clutch System
    New Honda Inner/Outer CV/TriPod Joints
    Custom Fabricated Hardened Driveshafts/w Custom Lotus Stainless Steel Hubs
    Custom Engine/Transmission Brackets and Shift Linkage
    Cost: $4K
    Custom Engine Bay/Cooling Management System
    Custom Sheet Metal / Cold Air Zone / Ductwork from Side Scoops
    Side Mounted Air Cooling Scoops/Ductwork
    Canton Oil Catch Can
    Canton Header Tank
    Custom Yellow Silicone Hoses ($$)
    Cost: $2K
    Cost of Upgrades/Conversion: $32.5K
    Lotus Purchase Price: $30K
    Total Investment: $62.5K
    Selling Price: $49,900
    Is this car Street-Legal?
    No. When these cars were imported to the U.S., they were considered track-only vehicles. In fact, they have no VIN number and/or Title, but rather a S/N. This car basically just has a receipt indicating (1) Race Car. When I bought the car, it was licensed in Florida, but I’ve not attempted to register the vehicle here in Minnesota. That said, I do have a friend with the same-type car (Lotus/Honda) here in Minneapolis. He registered his as a kit car and drives it on the street.
    Want to see more on this car? Here is my build-thread…
    DIY Lotus Elise S1 Engine Swap: Fitting an Acura TSX K24
    Ken McNeill
    612-743-2317 (Call or Text)
    kenamcneill@gmail.com
  8. Derrian
    I see no fire, no fire = failed backfire :p
