Radical promises Le Mans-inspired RXC
Discussion in 'Car News' started by garagegeeks, Dec 14, 2012.
    Filed under: Motorsports, Performance, UK, Racing
    Radical is poised to release a new model called the RXC. A two-seat, closed-roof sports car, the machine should bow with a Ford 3.7-liter V6 with around 380 horsepower on hand and a curb weight of under 2,000 pounds. Designers borrowed from the company's experience at the 24 Hours of Le Mans to create a vehicle that looks more like an LMP1 entry than something road-legal. The body generates an impressive 1,984 pounds of down force and uses both composite and carbon fiber construction. Underneath the skin, the RXC boasts a tube steel chassis with an integrated roll cage. Radical says it will run the RXC through the same FIA crash test evaluations Le Mans racers must withstand.
    Should you require a bit more thrust, the RXC can be had with the same 3.0-liter V8 found in the SR8 RX racer. That lump churns out 480 horsepower and dumps it all on the rear wheels via a seven-speed automatic. Handling falls on a new bespoke Intrax inboard push rod race suspension with double wishbones on all four corners, and the RXC uses a hefty set of 13-inch discs pressed by six-piston brake calipers up front to slow the party. The rear brakes also use six-piston calipers, though they're paired with a 12.2-inch disc. Check out the full press release below.
    Continue reading Radical promises Le Mans-inspired RXC
    Radical promises Le Mans-inspired RXC originally appeared on Autoblog on Thu, 13 Dec 2012 17:44:00 EST. Please see our terms for use of feeds.
