DIY: Oil Catch Can
Discussion in 'DIY & How To's' started by derrian, Mar 9, 2011.
    Credit: Rotary Insider
    Link: http://www.rotaryinsider.com/diy-tac38/oil-catch-can-gap31.htm
    First you need an air compressor filter. Home Depot sells one that fits the bill for only $11
    The filter has a directional air flow, it comes in from one tube, is directed downwards, then at the top is an exit to the second tube. But it's not a direct path since there's a plastic bit in the way. This forces the air to touch the sides of the tube and hopefully change from oil in gas form to oil in liquid form, before it's sent off into your intake - and into your intercooler.
    You do not need the actual filter inside, so I took it out. But the filter holds up a plastic disk with prevents direct access to the exit hole. So I found a brass lug nut/screw thing that was lying around in my toolbox and used that to hold the plastic disk in place. You could also break up the filter and retain the black plastic nut that came with the unit.
    Home Depot also sold larger air filters, but I didn't bother for my first attempt. The bottom of the unit has a push pin that allows oil to be drained. You could also unscrew the transparent part and pour it out.
    The second thing you need are the brass screws that attach to the sides of the filter. I don't have any before photos, but you'll find them sold right next to where you picked up the air filter. They ran me about $1.20 each. You'll need two.
    Now cut into your return line and put the filter in place. The size of the fittings on the side of the filter will exactly fit the hose that your car already has.
    I'm currently in progress of making my own CAI, so for the time being mine's zip tied. I'll have better photos of it later.
    the top of the filter has mounting holes btw
    Total cost: ~$17. This includes tax, and some thread sealant tape.
  2. ij1889
    ij1889 New Member
    ive been thinking of doing this...
  3. Shwangtwong
    Shwangtwong New Member
    ive been thinking about making one at work with some scrap aluminum. i know i dont have any power to really need one. but it sounds like a fun project to try.
  4. Derrian
    I've heard they are good either way. Just getting that junk out of your oil is good for your car, no matter what. Erik wants me to have 2 :)
  5. Shwangtwong
    ill figure it out and let you guys know how it turns out.
