DIY: Nissan 370Z Oil change
Discussion in 'DIY & How To's' started by derrian, Apr 18, 2011.
    Courtesy: AK370z The370z
    Link: http://www.the370z.com/diy-section-...0z-oil-change-ak370z-way-pictures-inside.html
    What you'll need?
    Redline Synthetic Motor oil (5W 30)
    Buy Here or Here
    K&N Oil filter
    Buy Here
    Magnetic drain plug
    Buy Here
    FilterMag Oil Filter Magnet
    Buy Here
    Copper drain plug washer
    Buy from your local Nissan dealer ($1.04)
    How to
    Step 1
    Run the engine until it reaches operating temperature.
    STEP 2
    Then you need to lift your car. You can use blitz ramps. Once the car is on the lift, turn the engine off.
    STEP 3
    You need to remove the plastic engine undercover. It's held on by 16 10 mm bolts and 3 clips. Start removing the bolts first. Once you remove all the bolts, the undercover will hang by the clips. Now, remove the clips and you can take the cover off.
    STEP 4
    Once the cover is off, here's what you'll see. First, remove the oil filler cap (in engine bay). Then, use a wrench to unbolt the drain bolt. You should be able to unscrew the oil filter by hand (at least I was able to). Carefully put the oil catch pan right in between filter and bolt. Draining oil is VERY HOT. Please use caution as you unbolt the drain bolt or filter.
    STEP 5
    Wipe the engine oil filter mounting surface with a clean rag. Please be VERY careful since the surface is extremely sharp. You'll cut your hand/finger very easily if you don't pay attention. Coat the gasket on the new filter with clean engine oil. Screw in the oil filter clockwise until a slight resistance is felt, then tighten additionally more than 2/3 turn (as per manual 11 to 15 ft-lb). Pic 2 is comparison shot vs OEM filter
    STEP 6
    Now, install the magnetic drain plug with a new washer. Securely tighten the drain plug with a wrench. Make sure the flat surface of the washer is close to the head of the bolt. As per manual, Drain plug tightening torque: 22 to 29 ft-lb
    STEP 7
    Now, you can install (attach) the FilterMag oil filter magnet to the oil filter. The K&N oil filter diameter is 2.69 in (68 mm). So if you'd like to use filter magnet from another company, you're more than welcome to do so.
    STEP 8
    Now, refill engine with RedLine oil and install the oil filler cap securely. With the new oil filter, you will need 5 1/8 quart of engine oil. Or simply put 5 quarts first. And keep the 1/8 quart to fill later (to get accurate measure on level surface). BTW, Aquafina water bottle nozzle works like a charm! It's perfect fit and it'll stay in place between quart bottle change [​IMG]
    STEP 9
    Start the engine and check for leakage around the drain plug and the oil filter.Correct as required. Turn the engine off and put the undercover back on. First, Pull the center of the small plastic clip out. Then, hold the engine undercover into position. Insert the clip through the undercover into the hole in the frame, then push the center of the clip in to lock the clip in place. Once you have the clips secured, then install the other bolts that hold the undercover in place. Be careful not to strip the bolts or over-tighten them.
    STEP 10
    Carefully lower the vehicle and park on a level surface. Run the engine until it reaches operating temperature. Then, turn the engine off and wait more than 15 minutes. Check the oil level with the dipstick. Add engine oil if necessary (usually that 1/8 quart that you left in the bottle).
    YOU'RE DONE! [​IMG]
