woot cobalt
Discussion in 'Project Cars' started by BankerBalt, Aug 1, 2011.
  1. BankerBalt
    BankerBalt New Member
    represent
  2. 1Kris06
    awesome thread bro
  3. derrian
    derrian Administrator Staff Member
    hahaha Tim! post up your car stuffs :p
  4. BankerBalt
    car stuffs meaning what? what i've done to it and such?
  5. BankerBalt
    Engine:
    K&N Typhoon SRI
    2.4 Intake Manifold
    2.4 Throttle Body
    Bad-Mab Shorty Header
    ZZP 2.5" Catted Downpipe
    Tsudo N-1 Exhaust
    Trifecta Tuned
    Drivetrain/Suspension:
    FE-5 Shocks
    FE-5 Struts
    Dropzone Springs (2" Front drop, 2.5" Rear drop)
    SS/TC Front Sway Bar, 23mm I believe
    Moog Endlinks
    Moog Sway Bar Bushings
    TTR Solid Engine Mount
    TTR Transmission Mounts
    Exterior:
    Tinted Tail Lights
    USMC EGA Decal
    Some sort of random 17" Aluminum Performance Rims/Tires
    Interior:
    2008 G5 140mph White Gauge Cluster
    Blue Painted Trim
    done
    stupercharging it soon though. only need random parts left and a driveway *cough joelle cough* to do the install
  6. derrian
    Pictures!!! :p
  7. Grappler
  8. Straitup D
    your tire is low bro....
  9. BankerBalt
    so i was bored at work yesterday and made a list of my mods/replacement parts and other miscellaneous things that i've spent...
    Pre S/C
    k&n intake - 220
    tsudo catback - 250
    zzp 2.5" catted downpipe - 220
    bad-mab header - 190
    ttr engine mount - 190
    ttr transmission mounts - 55
    fe5 shocks - 90
    fe5 struts - 160
    dropzone springs - 120
    ss/sc front sway bar - 75
    sway bar bushings - 10
    moog endlinks - 50
    cosmo short throw - 90
    2.4L intake mani and tb - 130
    enkei wheels/hankook tires - 400/set
    winterforce tires - 160/set
    strut mounts - 30
    brake pads - 20
    rotors - 20
    alignment - 100
    led tail lights - 130
    tune - 225
    dyno - 60
    140mph gauge cluster - 60
    miscellaneous, i figure about 200
    S/C
    supercharger - 125
    intake manifold - 175
    throttle body - 75
    k&n cai - 100
    cx racing heat exchanger - 150
    modular pulley system w/ stage 2 pulley - 90
    install for pulley and hub - 50
    intercooler pump - 100
    42lb injectors - 40
    tensioner, idler and alternator bracket - 50
    ngk spark plugs - 20
    miscellaneous stuff through gm parts direct - 430
    aem wideband - 150
    autometer boost gauge (bought one and it broke, had to buy another one) - 130
    autometer volt gauge - 60
    zzp 3 gauge pod - 90
    miscellaneous bolts, gaskets, wires, fittings, hoses and bends - 150
    new supercharger coupler kit - 60
    ttr rear sway bar - 130
    stainless steel brake lines - 85
    shorty antenna - 20
    hp tune - 200
    i'm sure there's more. but that's all i wrote down. grand total of $5,735... lulz 4 cylinder domestic
  10. derrian
    So I hear you blew up your car :p
  11. Grappler
    Loool best parts is he can't respond for another three weeks till he gets back :p
  12. BankerBalt
    I hear my friends know how to rebuild engines and have the tools to do it while I'm gone. Dev has the key and parts are in my room.... Trollololololol kthxbai
  13. derrian
    LOL, expect you were paying us..... and wanted to be there to help :D
  14. BankerBalt
    well you all obviously know i blew up the car but why don't i just throw up here what's all going into it!
    wiseco pistons 10:1
    eagle rods
    zzp balance shafts
    supertech intake/exhaust valves
    supertech 76lb dual valve springs/retainers/seats
    supertech valves (intake/exhaust)
    supertech valve guides
    supertech seals
    new crank (w/ main/rod bearings)
    exedy lightweight flywheel
    exedy stage 2 clutch
    twm shifter bushings
    dual pass endplate for intake manifold
    extra secondary coolant resevoir
    80lb injectors
    2.8" pulley
    new timing chain set
    rear main seal
    front main seal
    arp head studs
    arp flywheel bolts
    cometic multilayer head gasket
    girdle bolts
    new intake/exhaust gaskets
    catless downpipe
    oil catch can
    crank will be getting balanced for new parts
    after break in will be going E85 along with starting to put parts together for turboz
    there's probably more but i can't think right now.
  15. BankerBalt
    since erik, james, devlin and i decided to have a match to see who's got more money in their car... here's a list of my parts minus the shipping costs and minor maintenance parts/prices.
    K&N Intake - 220
    Bad Mab Header - 190
    ZZP Downpipe - 260
    Tsudo Catback - 250
    TTR Engine Mount - 180
    TTR Tranny Mounts - 55
    FE5 Shocks - 90
    FE5 Struts w/ Mounts - 220
    Sportline Springs - 130
    Moog Endlinks - 55
    SS/TC Front Sway Bar - 75
    Moog Sway Bar Bushings - 10
    TTR Rear Bar - 140
    2.4 Intake Manifold + Throttle Body - 130
    Trifecta Tune - 225
    Cosmo STS - 90
    Enkei Wheels w/ Hankook Tires - 400
    Winterforce Tires - 160
    LED 3rd Brake Light - 20
    LED Tail Lights - 120
    Black Halo Headlights - 120
    140MPH Gauge Cluster - 60
    M62 - 125
    Throttle body - 75
    K&N Intake - 100
    Intake Manifold - 175
    Pulley System - 90
    Miscellaneous (Belt/Gaskets/bolts/Brackets/Hoses) - 600
    Gauge Pod - 90
    Wideband - 160
    Boost Gauge(s) - 120
    Volt Gauge - 40
    CX Racing Heat Exchanger - 150
    IC Pump - 100
    42LB Injectors - 120
    HP Tune - 250
    5285
    Wiseco Pistons/Eagle Rods - 775
    Crank - 200
    Bearings - 50
    ZZP Balance Shafts - 260
    Cam Timing Set - 105
    Balance Shaft Timing Set - 80
    Option B - 105
    Dual Pass Endplate - 60
    ZZP Catless Downpipe - 160
    Supertech Spring set - 315
    Supertech Valves - 260
    Supertech Valve Guides - 100
    Supertech Viton seals - 20
    Cometic MLS Head Gasket - 90
    ARP Head Studs - 160
    Main Girdle Bolts - 150
    Exedy Stage 2 Clutch - 300
    Exedy Lightweight Flywheel - 300
    Slave Cylinder - 90
    80LB Injectors - 220
    2.8 Pulley - 55
    Shaving Head/Installing Components/Honing/Cleaning - 600
    Intake/Exhaust Gaskets - 45
    Ebay Catch Can - 2
    car now runs and at about 450 miles. 50 miles until my first oil change and then i can get into boost :)
  16. cmspaz
    Not even a total at the end?
    I'm in for this game, btw.
  17. BankerBalt
    I know I forgot a few things. It's just around 10k. More than I paid for the car
  18. Grappler
    Ungh.... now I have to go look at receipts and things
  19. derrian
    LOL to the price wars :) I'll just say (on one line even)
    $3000 - Wheels and tires :D
    Either way, congrats on a built engine that started up and is now running!
  20. Grappler
    I have over $1200 in the fuel system alone...
