so after some drifting my car has started burnning a LOT of oil, when i stop for a second or two rthen accelorate a rather large bit of smoke comes out, rings? or valve seals?
Rings will smoke damn near all the time, stem seals will only smoke under heavy vacuum. Could however be that you dropped a couple valve seals and that'll smoke all the time as well.
that is what i have been getting told. so i am inexperienced, is this something that i can do at home or should i take it to a machiean shop?
